In the '96 owner's manual, page 383, fuse 19 is listed as ignition coils and PCM.
However the wiring diagram also shows it connects to the radio capacitor, which it should, to put the capacitor in parallel with the ignition coil noise to shunt it to ground.
I might try process of elimination. Unplug the connector to the ignition coil driver module and see if the fuse still blows. If it does, disconnect the radio capacitor and repeat the test. If it still blows, probably a short in the PCM relay which seems less likely but to be thorough, unplug PCM relay and repeat the test. Note that I wrote relay not PCM itself. Fuse 19 appears to only power the relay coil, not supply power to the PCM itself.
However when doing the unplugging, disturbing the wire could temporarily remove a short due to wiring insulation failure, but if there is a short like that, and considering it's a 25A fuse, that type of short and amount of current might create a spark in the engine bay that you might see if it's dark, but more practically speaking, if you have unplugged all 3 things listed (capacity, coil driver module, and PCM relay) and still measure low resistance to ground, a wiring short may be all there is left as a cause.
An alternate approach instead of blowing fuses till you find the fault, is pull fuse 19 ahead of time, then turn the ignition on, then measure for 12V on the fuses box contacts between each and chassis ground to find the upstream battery supply side. When you find which side of the fuse has 12V, next put the multimeter in resistance mode and probe the other side of the fuse contacts, the downstream side to the loads, measuring resistance between that side and chassis ground. From this point forward, once you identify which side of the fuse contacts goes to the loads, you do not need the ignition on for for the following tests:
Presumably there is very low resistance since it's blowing fuses, and you can see if that low resistance goes away when you disconnect the coil driver module, and then the radio capacitor, and then the PCM relay.
Wiring diagram attached. Hopefully it 100% applies to a '96 even though the under hood power distribution box may be a bit different.
