Sbyrne97
- February 18, 2008
- Mason Neck, Virginia
- 97' Mountaineer
Hi I'm about to do the 3" BL in a week on a 97 mountaineer to put on my 33" BFG MT
I have spent the past week looking at shadowravens writeup and mudmarines writeup along with reading the guide inside the kit
I just have a few final questions...just to clear up
The front mounts are supposed to be a huge PITA and most are not reused
I heard you can get a bolt and washer to replace it is this correct and what length is required?
The front pucks also have to be drilled out correct?
Bolts need to be bought from a hardware store correct? I just want to make sure there used in the front mounts behind the seats?
Are all the original nuts used?
I heard some trouble with the shift linkage cable...is this a major problem? and what do you do if you run into it?
Finally, if you all have any other advice/things that I might have missed it would be greatly appreciated
I will another person (along with myself) working on this so I have a hand...
Want to say thank you to all you guys...you have gave me the confidence to tackle this
