Brake rotors on my D44 Axle | Ford Explorer Forums
there is either bolts that hold the two together or just pressed together w the wheel studs... loosen and remove the bolts and seperate the hub and rotor w a BFH. if no bolts, remove the wheelstuds and seperate...i'm tryin to picture the hub and rotor in my head, but im pretty sure thats how it is....:rolleyes:
Put a nut on the studs and smack with hammer on each stud. It's backwards then what you think. Studs fall right out and rotor is free.
? i thought that was what i said
my bad rookieshooter
