smashclash
- July 29, 2016
- Location
- South Jersey
- 2014 Ford Explorer XLT
A month or so ago I changed the front rotors and pads. Ever since I get a squeal/sound when braking at a certain pressure. If you press light or hard there's no sound. I'd say you only hear it when you're braking at normal using a normal slow down pressure. There's been several hundred miles put on now so I think it should be pass any break in period. I wiped off and put brake grease on the caliper bolts when installing them. I also put some grease on the clips that hold the brake pads. I didn't go crazy, just a nice thin and even coat. I did not apply grease to the back of the pads (part that comes in contact with the calipers.)
What else should I try?
Here's the rotor and pads I got if it matters:
CENTRIC 90865068
CENTRIC 90865068
