NPGuy
- December 5, 2015
- North Pole alaska
- 1991 Ford Explorer Eddie
Greetings,
I was on this forum under a different screen name a few years ago but could not reset my password.
Now to the problem description.
I have a 1991 Ford Explorer Eddie Bauer edition with a 4.0 liter and a A4LD.
I have just completed a complete engine rebuild and everything was new with the exception of the block and rods and a few external parts. New Pistons, crank, cam shaft, lifters, basically everything, heads have all new valves and springs also.
So I was careful and measured all the clearances and super clean building the engine. Everything was coated in assembly lube as it went together. Followed the book to a T thinking I would have a engine that would run like new. Fast forward to now. Got the engine in and everything all put back together, primed the engine and fired it up and it started right up and seemed to run ok. Figured after all the new engine paint burned off and things seated it would run nice and smooth. I followed the engine break in procedure in the service manual for seating the rings.
Now to the problem
After about 100 miles now I still have a tick at idle. It sounds to me like a lifter tick from somewhere around cylinder two or three. I can't hear it above idle and it is only after it warms up good and warm. Quiet at idle while engine is cold.
I did find a TSB for something like this for a different ford engine that effected 1991 engines.
It made reference to a bad or out of spec cam shaft thrust bearing. That is one of the only internal parts that was not changed due to not being able to find a source of that part.
Now for more of the story
The engine had a tick at idle prior to tearing it down, it did sound like it was coming from the other side of the engine though and a few mechanic friends and myself figured it was a rod bearing with 175,000 it seemed plausible.
So who here can help me solve this issue before I have to pull the engine again. I need the engine to be reliable so I will do whatever I have to.
Thanks in advance for your help.
Now to the problem
