Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
So I pulled the pan to replace some of the tranny fluid on my A4LD. While I was in there, I thought I'd adjust the bands and re-torque the valve body bolts, since it hasn't shifted right for about 2 years. By not shifting right, I mean 1-2 had to be done by moving the shifter from D-OD, you couldn't get 1st while in OD and you couldn't get 2nd while in D.
After in 2nd, you had to let off the gas all the way and way for about 3 seconds and slowly reapply the throttle and you would get 3rd, and 4th always worked fine.
So with the pan off, I was looking around and noticed the Intermediate band looked like it was off or something. I noticed it was only partially on the drum. So I thought, "maybe I can just loosen it a little and move it back then tighten it".
Well, I was starting to get it tight then felt something give. Backed the adjuster bolt out and the thing on the end of the bolt (don't know the name) practically fell out. Got to looking, and realized the retainers on the band itself for that side were gone (or bent flat, who knows which one).
So my question is, is there any fixing this without removing the transmission? I didn't know if there was any way to replace the band somehow with just the VB off. I wouldn't think so, but transmissions are new ground to me.
