Bronco II= no run now | Page 3 | Ford Explorer Forums
Well made it to work with no problems:thumbsup:
still has a little bit of weird idle, but very small! 950-1000rpm.
I'll clean the IAC valve,and check the timing tommorow, when we fix the valve cover leak. I found the good gaskets for $39 bucks;)
Thanks for all your help Jamie;)
PFFFT no problem this is all the stuff I can onto these forums needing help with so what goes around comes around
Glad it made it to work and back, my 2.9L only left me 100% stranded one time, and it was a completely broken wire leading to the coil.
Pretty damn reliable truck with the 2.9L and a 5 speed that is for sure....
1987 ranger
set up for 5yrs. got it running went ta start it not pumpin fuel hotwired it . only will run with carb cleaner r startin fluid
