can anyone tell me if this is true? | Ford Explorer - Ford Ranger Forums - Serious Explorations
eworx
Hopkins, MN 55343
99 Explorer XLS 4.0 OHV
I Started a thread on here asking fir Info on the Warrior Shackles ( yes I did do a search for the info I was looking for ) Here is the Problem I got 2 different sets of measurement info.
Info from Warrior:
OUR 153 SHACKLE PROVIDES 1 1/4" LIFT AND IS 10 3/4" LONG TIP TO TIP. THE SHACKLE CENTER IS OFFSET WITH MEASUREMENT FROM HOLE CENTER TO HOLE CENTER OF 9 3/4".
Info from other:
War-153 are 8.5" long eye to eye measurement
can some one Please help?
Thanks,
Brice
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
Brice,
Maniak is correct in what he posted on your other thread. He measured from eye to eye and not from tip to tip. it should be measured from eye to eye, that is where you actually have the distance seperation between spring and mount. He is also correct on how much lift you will get, because you will get only half of the differance between the stock shackles and the Warrior shackles, because you are only lifting one side.
eworx
Hopkins, MN 55343
ok thank for your help
