TurboR
- October 27, 2003
- Waterford, MI
- 2001 Explorer Sport
I have a 5 channel alpine amp coming in the mail any day, is it possiable to hook up 2 sets of alpine typr R 5x7's, 1 pair of alpine type R 6x9's, and a jl audio stealthbox?
Here are the specs:
AMP:
Key Features
Amplifier Type Multi Channels
Bass Boost With Bass Boost
Bridgable Bridgable
Power Output
RMS Power at 2 Ohms 40 W x 4 + 150 W x 1
RMS Power at 4 Ohms 30 W x 4 + 150 W x 1
Performance
Frequency Response 10 Hz - 50000 Hz
Low - Pass Frequency 50 Hz - 200 Hz
High - Pass Frequency 50 Hz - 200 Hz
Signal to Noise Ratio 100 dB
Bass Boost Frequency 50 Hz
THD at Rated RMS Power .08 %
Dimensions
Width 16.44 in.
Depth 9.69 in.
Height 2.69 in.
Other Features
Input Voltage 11 volt
MOSFET amp Yes
3 Way Ready Yes
Miscellaneous
5x7's:
Alpine SPR-574A
Features:
• 140W Peak Power
• 35W RMS
• Frequency Response: 48Hz – 30kHz
• 3/4" Soft Dome Tweeter with 15° Swivel Capability
• In-Line 12dB HP Crossover with Tweeter Protection
• Aluminum Coated Poly Cone
• Cast Aluminum Woofer Fram
• Great fit for most Ford and Chrysler vehicles with 5x7 applications!
6x9's:
Alpine SPR-694A
Features:
• 120W Peak Power
• 50W RMS
• 1" Soft Dome Tweeter with 15° Swivel Capability
• Cast Aluminum Woofer Frame
Stealthbox:
The Hard Data:
Contains one 10W1-4 in a sealed enclosure. 125 watt power handling. Wired for 4Ω mono. Fits both 2 and 4 door versions of these SUV’s. Installs inside passenger side cargo area trim panel. Black, cloth-covered grille included (see in-car photo). Stealthbox® installs with absolutely no loss of cargo space!
Here are the specs:
AMP:
Key Features
Bridgable Bridgable
Power Output
Performance
Dimensions
Width 16.44 in.
Depth 9.69 in.
Height 2.69 in.
Other Features
MOSFET amp Yes
3 Way Ready Yes
Miscellaneous
5x7's:
Alpine SPR-574A
Features:
• 140W Peak Power
• 35W RMS
6x9's:
Alpine SPR-694A
Features:
• 120W Peak Power
• 50W RMS
Stealthbox:
The Hard Data:
