Tom Wilk
- July 31, 1999
- Chattanooga, TN
- '99 Sport
Gerald, its not worn out, but there is some slop in there that wasn't there before. Still has the limited slip action, but I think I took some surface off the clutches. I'm pretty doggone sure its just wear.
There's a small amount of end play in the axle shafts, and there's a little movement in the spider gears which leads me to beleive that the clutches have seen some wear. Since the clutches are very thick and the spring pack keeps them tight against the sides of the case, the limited slip action is still there, but if I rock the vehicle back and forth very hard, you can see the slack in the spiders being taken up as the clutch moves against the housing about 1/16" or less. That play wasn't there before. I pulled the cover off a couple of weeks ago to inspect. I also checked the breakaway torque which is still 100 ft-lbs.
Oh well, next year I'll be putting a locker in, I think.
