If you got honeycomb, your secondary sensors will be throwing a flag and your running on the stock mappings that are rich to make sure nothing burns out. Once you replace the cats expect your mileage to jump as well.
@Tech By Trade
Been getting P0054 "HO2S Heater Resistance Bank 1 Pos. 2 every single time I climb a certain long hill coming back home. Runs, drives just fine, erase DTC, drive any length of time, no DTC until up that hill! Done this many times, just to prove it out. Completely removed the harness question by wiring 4 new conductors from the 1-2 sensor upstairs to B+, and PCM. Same thing, same DTC.
Yesterday evening I had the old lady run the engine at 2500 rpm, while I beat on the Bank 1 Cat. Not hard enough to dent it, (has a thin shield welded around it anyway), gave it maybe 12 good hits. Drove downtown today, back up that confounded hill, NO CEL!
Gimme a break! The Ford Troubleshooting Manual guides the Tech through all the possible resistance checks, voltage checks, but fails to mention Cats! Even says if harness OK, replace PCM! I have a spare PCM, BTW, and IT throws the damned DTC just the same!
Tomorrow I'm driving that frigging hill again! Then order new Y-pipe and Cats. imp
EDIT: FWIW, checked PIDS running, downstream HO2S's show NO VOLTAGE OUTPUT when started up. Takes quite awhile to appear. A guy could look, see no voltage, shut down and replace a good sensor.
