stanlam
- January 5, 2011
- Los Angeles, CA
- 1992 XLT
I have a 1992 Ford Explorer with over 200,000 miles. The car is stock with 2 wheel ABS brakes. The problem is the brakes are really weak. The brakes were inspected by a mechanic and everything looked fine. Then the mechanic tried to bleed the brakes. The front brakes bleeded fine, but the back brakes didn't bleed at all. From there the master cylinder was replaced with a new one. After replacing the master cylinder, the back brakes would bleed better, but still very slow. The brakes was tested again and the brakes are still weak. Any suggestions? Is there something about the 2 wheel ABS that is making this job confusing?
