Travis Brown
- February 19, 2020
- Location
- California
- California
- 2006 Ford Explorer XLT
I recently swapped my gauge cluster color from black to white to improve visibility in bright conditions. I thought it might be useful to some people. Here's what I did:
1) Find a white-backed gauge cluster at junkyard follow removal instructions here
2) Disassemble the white cluster, it's mostly just a bunch of plastic snaps. I ran into some trouble because the center LCD display had some glue holding it to the black plastic trouble light filter. Watch out for the delicate ribbon cable when you remove the circuit board. The hardest part is removing the needles from the tach and speedo, you have to pull frighteningly hard to get them to separate from the shafts. The temperature and gas indicators are easiest to remove by separating the motor from the circuit board. You just push the center of the white mounting pins inward and then they'll pop off the board. When you're done, you'll have something like this.
3) Once you have the circuit board and needles removed, the gauge faces themselves come off easily by just lifting them off their alignment pegs and rotating a few degrees to clear the center. you should now have something like this:
4) Disassemble your old black cluster and just swap the gauge faces over.
5) Put your cluster back together. This isn't too bad, but it can be a little tricky. First, remove the white pegs from the center of the coolant/gas indicator mounts. Then snake the coolant/gas indicators into the body, and move the circuit board into position, snapping the coolant/gas indicators into the board as you go. To secure the mounting, reinsert the white center pegs. The next part is probably the trickiest and I had to do it a couple times to get it right. You need to make sure the speedo/tach motors are all the way to their left most position, then push the new needles down onto the shafts. I got it wrong a couple times, so I suggest pushing them down part of the way, then plugging the cluster into your car and checking their position. Note: you could probably use this technique to do a crude adjustment of your speedo for bigger tire sizes.
6) Once all of the needles are back on and in their correct positions, reassemble the cluster and put it back in your dash. Viola! High contrast gauges!!
