Thunder1der
- June 16, 2023
- Palm Bay, Fl
- 1995, Explorer, XLT
1995
Cluster gauge went out one day.
Removed instrument panel and took out each gauge.
Burnt plastic smell coming from the gas and temperature gauge set.
Slight discoloration on white plastic under temperature gauge housing only. Nothing severe.
Everything else is fine.
Circuit board/ film was cleaned and passed testing.
Bulbs exchanged for new ones since it was already open. Not LED.
Anti-slosh board was cleaned and passed testing.
I put it all back together and installed it back into the dash.
I turned on the truck and everything worked for 15 seconds before all of it shutting back off and the burning plastic smell from behind the same set of gauges.
Removed the cluster again.
I have all the correct fuses and relays in the correct spots.
None of them tested bad.
I no longer have a guess where to look for the issue.
Ideas?
Replacement gauge set doesn't work either.
Ideas?
