Wray-Wray
- September 3, 2008
- North Tonawanda NY
- 99 Moutaineer 5.0L
I understand that, but I'm still trying to understand how a wobble extension can cause thread damage. It's just a way to help you reach the plug in the first place to get it out and to tighten it down once hand tightened. Am I missing something?
yes ur missing the point(not trying to sound like an ass sorry) that most people try and use the wobble extension 2 tread on the plugs or other bolts n such(when they are new to mechanics) and the cross thread ****(and or strip threads).....like jackal just said....
u on the other hand understand that **** should be hand tight first(which im in no way insulting you....itz a good thing you think that way....i've fixed alot of air-head mistakes).....
the reason they can strip threads is because......you may have the ratchet straight but the play in the wobble or swivel extension can cause the plug or bolt to be slightly ****ed(meaning miss-a-lined) causing a plug or bolt to strip out and or cross thread when putting plugs or bolts inn....
