MorganG
- September 25, 2006
- Huntington Beach
- 2000 2dr
So I started a thread about being hard to start on occasion that can be found here (
http://www.explorerforum.com/forums/showthread.php?p=1517745#post1517745 ) and I will post the text at the bottom of this post.
The updates to the problem are as follows:
1. Vehicle check engine started to stay on all the time, where it used to only come on if the car wouldn't start and then once it started it would turn off.
2. used an OBDII and got this code
P0155
02 Sensor Heater Circuit Malfunction (Bank 2 sensor 1)
3. My friend did call back after she picked up her car and I posted on here to ask the tech if he checked the ECT and he said he did and knew that it was not the problem. But the thing is he can't find the problem and the car wasn't mis behaving (naturally of course) when she took it in so how can he feel comfortable saying I don't know what's wrong with your car but I know it isn't that.
4. I cleared the check engine light and the next day it came back on. The car is starting to run sluggish and is getting worse gas mileage,
I still think it could be the ECT, anyone have some words of wisdom?
orig. post
P0155
orig. post
Hey guys, I am new here, just trying to help a friend out,
She has a 2000 2dr Auto Explorer with the 4.0 I am assuming. She has taken it the shop 2x and they have not been able to reproduce the problem and can't really offer her much other than bring it back next time it does it.
The problem is occasionally she will go to start the car (cold start) and it will crank but not start. If she gives it gas, full throttle, it may on occasion start but idling really rough and she cuts it off. Most of the time the car starts fine. They have checked her fuel system but as far as I know nothing on the car has been replaced. The check engine light comes on during the malfunction, but after she lets the car sit (half a day) it starts up with no problems and no check engine light.
As far I can tell from what she has told me there is not really a rhyme or reason to when this happens (aside from it being a cold start), its only on occasion, about 2-3 a week. Seems to happen on the weekends, when she actually wants to go somewhere and not work
I was just hoping maybe the masses would know, have seen this as a common problem, have had it happen themselves etc., any thoughts would be appreciated
