- October 26, 2002
- Location
- Houston, Texas
- Houston, Tx
- '91 XLT, '08 F450superdty
I really need to rotate my t-case up a little bit to get better clearence for my front driveshaft between the tranny crossmember. The engine is already tilted a little and the mounts are welded. So the only thing I can thing of is trying to use a different bellhousing that doesen't angle the tranny towards the driver. Does anyone know which year bellhousing is NOT angled toward the driver and is sticking more straight up and down??? Anyone?
Second, I got my intake adapter and 94/95 throttle body in the mial. Good news was it did clear my A/C box for the most part. Bad news is there is still interference with the A/C box and throttle cable linkage which is on the side of the throttle body. I am going to have to do something about that now. Then I had to order an adapter harness to use the "tps" from the 94/95 throttle body with the earlier harness system. That was ok, it was only about $14.00. More bad news was the Egr valve set up is different. I have to figure that out now as well.
Third, I got my altenator in and that all went as planned thank God. Looks good and mounts perfect with the right harness connection.
Next, I am going to haver to make a custom pulley because I switched the water pump and timing cover to the shorter style. The dont make any pulley that is designed to let you use the 94/95 style short water pump and timing cover with the earlier style engine. I dont think it will be too hard if I just modify my stock pulley. I'll make sure to include each fix for these damn problems as I figure them out. Until then anyone with suggestions, please feel free to share them with me. Thank-you,
Tim
Tim
