xplorernewb
- May 6, 2014
- washington state
- 91 ford explorer sport
well ive had a couple previous issues with this and it seems to have gotten worse since ive replaced the MC, had a shop bleed it and there is no play at all now. but it still grinds, and even worse now.
in neutral, clutch pedal pressed to the floor, it'll make a grinding sound. more like a real big vibration grind like something isnt meshing. also it squeaks when i push the clutch in when the ignition is off, car not running. when it is running and i push the clutch in, if it doesnt make the grind sound, it'll make a clack sound when i release the pedal, followed by a squeak. the shop told me it could be the throw out bearing.. maybe the pressure plate too? or the transmission is just shot? the clutch is like 6 months old, not sure if the shop replaced the flywheel or not. dont remember. maybe its the flywheel itself? someone heeeelllp
