Diddy74
- June 28, 2005
- Bronx
- 1999 XLT
A curious thing happened to me today. I had the hood up doing some simple routine maintanence, checking fluids, changed the air filter etc. I cranked it up make sure everything was running smooth..so I was about to wrap things up and just took a towel and was lightly dusting, wiping grime off different things no serious major cleaning. I had brushed over the coil pack and was reminded the #1 rule of basic electricity...it wil travel the path least resistance! yup got a shock...To be sure nothing was loose and find out which one gave me the jolt I checked each one making sure the wires were seated snug and the plastic clips were locked..then when I got to #3(I think, its goes to the last plug closest to the firewall drivers side) I got another jolt just from grasping the clips. I shut down the motor and carefully examined the wire and the coil pack. I couldnt "see" any anomolies and I made sure the wire was seated and locked in making good contact....what could be the culprit?
