- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
Last time I took the X out wheeling I managed to pop the front right spring out of the coil bucket three times. Once was when climbing a rock ledge and when that spring was out I ended having to drag the body of the truck over the ledge since the truck was lower w/out a spring holding it up.
The first time I put the spring back in the correct way (the end of the spring ended up where it is supposed to go).. The 2nd and 3rd time it happened I rotated the spring to try to get a little more meat to hold the spring in.. It been staying in since then, but I haven't flexed the truck since then.
If anyone has any insight into why this is hapening (why it pops up, when the drivers side doesnt' seem to have the issue) I'd appreciate it...
I was thinking of possibly using a j-hook as a spring keeper to hold the spring in, but I figured that would just limit my suspension travel (droop)..
I remember reading a thread years ago about someone modding the coil bucket to allow the spring to pop out and then pop back in when the suspension compressed some. It was noisy, but worked.. and of course, I can't find the thread.
My only other option is to use shorter shocks, or limiting straps (I don't like either idea).. If I use shorter shocks I could trade droop for stuff, but I figured getting more droop is better than more stuff when rock crawling (I don't jump the truck)..
My current front suspension is Duff 2.5" lift progressive rate coils on top of f-150 spring spacers with Duff 2.5" drop brackets for RA and pivot.
~Mark
~Mark
