- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I’m sorry but those rigged ridge hubs for the 98-99 ranger are garbage
Hold a set in your hands and you will see what I mean. They press fit on and are light duty. The two sets we had failed first time out. I currently have a 98 ranger with these installed. I will be removing them and installing 2000 explorer knuckles and run a live axle
If you want to disconnect the front axle for more power or mpg then should consider the 95-96 cad front diff and the mods needed to make it fit w the v8. Set it up to use a switch or cable and not vacuum = the hot setup. I’m planning this for my 03 trax see just how much mpg we can get from a 5 speed 4wd v8
Why not run a torque on demand 4406? We can get or create a stand alone tod controller and this case will bolt in.
The flat pans are for rwd,
Would make it easier to set the trans on the floor? I just made a simple wooden jig for my trans jack that fits the 4r pan
