Custom A/C lines??? | Ford Explorer Forums
Custom A/C lines???
Turdle
DIY stunt double
Staff member
Moderator
Humboldt, KS
2000 Mounty
I need to have the upper hose from accumulator to the compressor custom made-or straightened. It is a clearance issue with the different intake manifold angle. I'm trying to get my truck tuned finally--the intake tube -ac line clearance is causing me a great headache while trying to build a better intake--
Where can I get a custom ac line made?--or is there a better way? Ideas are welcome--
I went to 2 local places, they suggested a flexible extension, but couldn't find enough straight pipe to clamp (press fitting) it on to--
now, the big problem is that it is actually part of a manifold type thing on the compressor, with another line which comes from the condensor being part of the assembly also-
Yeah take your old hoses to a hydraulics shop.
If the end fittings are non-standard, they should be able to chop off a small section of the end and re-use them in a new hose.
If they are standard, then it should be no problem.
I find myself browsing endlessly when I visit the hydraulics shop -- I sometimes wish they'd take twice as long making a hose or whatever so I can have more browsing time.
it looks like this--(ebay picture)
to the left is the line I need straight--see how the other end is part of the manifold? There is no connector there. It is just kinda welded-
On the free end, the pictured one looks damaged or bent and crimped a bit, mine is actually s shaped there--
The 2 places I took it too suggested what you said Iz, --but the bend in ther pipe is too close to get a straight run for crimping.
These are the spring clip fittings-are these fittings available? If so, maybe a complete hose crimped at the manifold thing--making a complete new line??
If all your options run out and you dont have a welder and that manifold is steel, send it to me and the new section of steel tube and I'll weld it for you.
We won't do this if the hose fittings are different mfg than the hose mfg.
Each mfg has different crimp specs for their hose & fittings.
Auto A/C lines have different threads than industrial fittings. They are also aluminum instead of steel.
I know O'reilly's advertises custom Gates hoses and gates is a mfg of A/C hoses.
Goodyear also has A/C hose fittings and hose. I would make you a hose Jon but we would have to order a minimum of 250' of hose as we do not stock Goodyear Hydraulic hose.
However get me the size (i.d.) of the hose & I will see if our rep can get me a sample piece. If so I will just need to see your old hose to match up the cplgs.
Is there a real AC shop close by?
I suspect that most AC places today, only change parts and re-charge.....but, the old timers may have the tools to do the crimps and fittings on a new hose. Check the yellow pages.
IF you live far from a "big city" finding an AC shop with the tools may be impossible.
Aloha, Mark
This has proven to be difficult--
I'm even having a hard time finding a shop just to reclaim the refrigerant. They all tell me it is cheaper just to "let it spray!!"
I'm going to try a different route. I didn't want to do this, but I think I'm going to get an intercooler piping kit to get around it--:(
I'll need about 5 out of the 45 parts--lol
many napa stores cam name you custom hoses/high pressure lines.
I have ALWAYS found what I need off other year/model Fords :)
OK-this is just hell--
The darn AC line is just in the way. Instead of going around it with an intake tube--how about this--
Can I relocate my drier (accumulator) bottle-and run a new hard line from the evaporator to the bottle? These fittings would be easier to make--
