96ExplorerXLT
- January 26, 2004
- Omaha, Ne
- 2005 XLT
that isnt the stock intake tubing and MAF is it??
BigBadWimp said:Would you say this is just as good as the kkm inatake? It sounds about the same...
DeRocha said:There had been discussions with Warren from KKM to actually manufacture a new intake tube to free up the restrictive 1st gen, but it has not gotten off the ground (start up cost was to high).
huskyfan23 said:extended the MAF wires,
NO difference at all. I believe Ford vehicle MAF's read pulse, not voltage, so as long as the connection's good there won't be any adverse affects.Rhett said:Have you had any problems with the running condition of your truck since you extended the MAF wires? Or has it made no difference?
Do this mod meaning what? Adding an open-cone filter or drilling your airbox? With the open-cone you might as well remove the bottom part of the airbox.CdnCory said:When I do this mod, should I leave the bottom 1/2 of my airbox on?
