dana 35 4.10 shim ??? | Ford Explorer Forums
cashmoney37
South Bend, IN
2000 mountaineer
i am about to swap a set of 4.10 gears i am gona swap into my dana 35. any body of hand know what size shims i need to set 4.10 up.
Size of Shims?????
My friend, if you do not already know that ALL ring & pinion gearsets require shimming to be done on a custom basis, ALL gears vary slightly, and therefore require shim thicknesses of their very own, to establish correct tooth contact pattern and backlash (clearance).....you are in for a helluva rough time.......imp
