IZwack said:10-15 mins? Wow you're closer than I thought!
Yeah please PM me your cell number, I might stop by this weekend (Sunday?) just to see how you're doing your SAS. I also should snap a few shots and upload them for you - you have shown no pictures YET!! You know thats a crime when doing an SAS![]()
Blee1099 said:damn the garage still looks like that.. Hopefully one of these days, you'll actually be able to put darkness inside![]()
FROADER said:You can put the coil buckets wherever you want to make it whatever height you want. I've got the wild horses 5.5.
MEANEXPLODER said:Where Did You Get Your Spacers?
Nick26 said:awesome, i'm glad i found this thread, i have the same exact axle and I wasn't sure how exactly i was going to narrow it until i saw you do it... I was considering drilling out those welded plugs on the differential housing where the long tube goes in. that looked the easiest, is there a reason people don't do it that way?
when you cut it with the chop saw did you cut it flush with the end of the radius arm mounting area or did you leave a few inches hanging out for pulling on and grind the welds off?
Savage Wolf said:How Not to install a v8!
haha you do everything the hard way i guess then... well i got the axle and whole coil spring front suspension for free, its high pinion, and theres no way i can run full width in New England... so i'm going to give it a shot. im always up for a challenge, besides you made it look easy in your thread.Savage Wolf said:to be honest cutting down the 78/79 d44 is the last thing i would recommend someone to tryits a total pita
i don't understand exactly what you drilled, did you drill the tube lengthwise to make it c shaped? How did you manage to pull it out? were you able to tap the lip of it with like a long screwdriver from the knucle end?Savage Wolf said:drilled the tube peice out w/ aprox 14/64 drill bit to make hammering it out alittle easyer
Nick26 said:haha you do everything the hard way i guess then... well i got the axle and whole coil spring front suspension for free, its high pinion, and theres no way i can run full width in New England... so i'm going to give it a shot. im always up for a challenge, besides you made it look easy in your thread.
Hey Wolf -- cya at Paragon eh chap? Save some sushi for me - thanks!
oh and merry kurisumaSUU!![]()
Well I hope to wheel with you at some point!I wont be making the newyears run, seems that my matching 4.10 geared axles arent matched... one is coming out to be 4.2 gear ?wtf and 3.53.....
