earlrengland
- July 11, 2009
- 2002 XLT
I just installed a reman 5r55w in my 2002 Explorer. After about the second day of driving it, the O/D light came on, but the transmission shifted fine. The light would actually go out after about 5 miles or so, but gradually got to the point that it stayed on all the time. My OBDII scanner showed no issues with the unit, so I thought that I might have overfilled it when I installed it. Sure enough, I had about one quart to many in it. So I drained it down to the level that it needed to be, and the O/D light went back to blinking only when I started the truck, but then went back out after a short period of time. HOWEVER, I took the truck for an extended drive today to Indianapolis, which was about 160 miles one way. Everything seems to be ok until I tried driving home. I made it as far as Kokomo, when all of sudden the truck died for no reason, and it is now stuck in what seems like 4th gear, and I received the following error codes from my reader:
P0755-Solenoid B Malfunction
P0743-Torque Converter Clutch Circuit Electrical
P0760-Solenoid C Malfunction
P0797-Transmission Concern
P1747-Electronic Pressure Control Solenoid - Short circuit
P1789-Transmission system problems
Any suggestions?
Any suggestions?
