Yes I did install them and they are still working great! Even after sitting in the AZ sun for all this time the connectors are still solid with no signs of UV damage.
The magnet is VERY strong and requires a real good tug to remove.
About the only thing I have had to do is clean the contacts with a spray of electronic contact cleaner and a 3m scuff pad. Since the contacts are all facing you they are easier to clean than the tabs on the old style connectors.
I recommend getting the adapter plug so that you can plug in "legacy" connectors should you have the need to tow someone else's trailer, of if you have to rent one.
