DoraAExplorer
- December 23, 2020
- Fayetteville
- 2023 Ford Ex Timberline
Locked 4wd sucks for anything other than a 8k pound CCLB SuperDuty, explorer is too light. Sand mode seems the most aggressive but pretty sure the transfer case is just a viscous with no clutches or locking coupler. So hard to find info on the transfer case or front axle disconnect. I will say the first time in bad weather my butt was puckered up hard in the explorer. Haven’t heard an ABS unit run this much since my 1993 accord or 1994 probe GT, two of the most horrible winter cars ever. Now the other guy at my work running an explorer XLT on 20s worked at Subaru and owned many says the Explorer is a beast. Glad it’s a company car, I ditch it and hit a tree I’ll get a ST next time.
LOL, this is wrong on so many levels. The Ford FX4 package includes 4L and 4A this locks both front and rear diffs together giving 100 percent traction. I owned a Subaru Forester with X Mode and it had Bridgestone crappy tires and it would hold on any type of slippery road regardless of tires. The ability to lock the diffs front and rear either from a viscous LSD or Torsen LSD will always provide better traction than open diffs being under the control of brake vectoring. The Explorer would be vastly superior with actual LSDs in the rear and with the AWD setup for the front as well.
It doesn't make for confidence inspiring AWD setups. I could spend all day talking about Subaru and their AWD as it is a benchmark system when combined with its boxer engines makes for a formidable setup. Granted you only need the system when you need the system and what usually is less than a week of these conditions for us made no sense to get the AWD Explorer. At least Ford could add the options to the Explorer line up which would raise the price which is probably why Ford hasn't put the technology into the Explorer. I would be happy with a LSD rear instead of a brake setup which combined with the tires provides inferior traction.
