johnnydee3
- June 25, 2006
- petoskey, mi
- '91 XLT
wont 4:11s be to hard on the engine when your on the highway?
Not at all... 4.10s with 33s will be the same as running 3.55s with stock tires (235/75R15). Follow the link in my sig line for axle gear calculators..
Find new Gear Ratio with new tire size
If you input new tire size 33, old tire size 28.5
You'll get a gearing value of 4.11
this value will give you the same performance you currently have (maybe slightly more power depending on the actual tire diameters involved since not all tires are exact measurements from manufacturer to manuafacturer.
In a nutshell if you're running 33s tires and regear to 4.10s it'll feel the same as running stock tires with your stock 3.55 gearing.. If you regear to 4.56s you feel a noticeable increase in power. The trade off or balance is power vs economy when running highway speeds. Again plug in the numbers in the RPM section and you'll see that with 33s and 4.10s you'll be running 2,035 at 65mph.. with 4.56s you'll be @ 2,263 rpm.
um...is says that 33s and 4.10s will run at 2713at 65 mph...when really at 2713 with 4.10s youd be goin 48 MPH.
what about with it not in overdrive
the shift kit will help to...and by the way...i dont really care that i wont be able to go screamin by ppl anyways..id prolly get better gas mileage cruisin at 65 and 1600 rpms
