does it matter... | Ford Explorer Forums
does it matter...
orion1998_1
Johnson City, TN
2005 mounty
on gen 1 (2dr) where heater hoses go? i was haveing trouble last year with heat, someone switched then around to see if it got better, dont remember what went where, i want to change heater core soon and run new heater hose, can someone tell me which goes where? thanks!
unless there is a leak you dont need to change heater core chances are you have a bad thermostat
yes small leak on tubes, i will replace t-stat too
No it matters not. And be thankful, on the 92 a core swap is a piece of cake....!!
thermostat and fluid change usually fixed heat problems
