Check for broken wires in the door loom, this is a common problem.
My power windows suddenly stopped working, traced it to a broken ground wire in the door loom.
I have also read that a liberal dose of WD-40 into the door lock assembly can help flush out any dirt or corrosion that may give a false door ajar warning.
If you search the forum you’ll see the door ajar issue come up often.
