Door stop on an '01 Sport Trac | Ford Explorer Forums
jccole@sbcglobal
oklahoma
2001 Sport trac
The driver's side door on my SportTrac will not stay open. Is there an adjustment to the door stop mechanism? Thanks.
The door striker plate uses a T50 Torx bit for the Trac.
Outline or trace around the plate before loosening for reference.
If you have to remove it or replace the plastic sleeve,
the rear nut is held in place with tabs and won't fall inside the pillar.
Allows for under 1/4 inch adjustment in all directions. GL
