Yeah I had to put the master on the bench, made it much easier. I actually stuck the check-valve end into the resiviour, and used a peice of tooth pick to keep the valve open. After a minute or two of pumping all the air was out and it was spraying straigh oil! The slave i used a pesticide pump sprayer to pump in the oil, of course it was cleaned out first! The oil bascially just runs out the slave, i used a screw driver to open up the valve on the slave.
Actually I've been thinking about that all day. hahah, a solid axle would probably keep me going straight a little better. Right now it’s so nice with 32's/4.56 and the 422 cam. I've got all this gear which the engine loves to use.
Whatever I end up doing, I am going try to keep the gearing lower then you would want a stock 4.0. This cam likes the extra low-ness to pick up, and get up past 2k. So if I went with 33"s, I might want 4.88's to go with it. I don’t know, I got to get a better feel for the new engine, I'm still being very cautious with it.
With the 422 cam, the 4.0 likes to coast around 3k-3.5k rpms. This is probably where ill get the best gas mileage. I want to try this thing in low range, mahahah.
UPDATE: 07-18-06
Before I can start looking up places that dyno near me, I got a coolant leak I need to straighten out.
I drove (8 miles) to work yesterday without an issue, other then the exhaust leaks which were more annoying then anything. When I left work I drove (3 miles) to Advanced Auto to see if they had any oxygen sensor plugs. They didn’t have any thing that fit, but in the process I noticed a boiling stream of drips coming down one side of the motor.
It wasn’t a huge leak; I maybe lost a pint at most. I drove it home keeping a close eye on the temperature, and proceeded to find where it was leaking. It was leaking around the upper hose for the heater core, which is positioned atop the lower intake. I noticed the clamp on this hose seemed loose, maybe I forgot to tighten it down or it loosened up somehow, but I repositioned it closer to the intake and snugged it down real good.
Water pooled around pretty much everywhere on top of the lower intake. Not in any extreme amount as I didn’t experience a significant loss in coolant, like a half a pint or so (on top of the intake).
Today, I went looking for those plugs again when I heard the faint boiling sound. The engine was not overheating, it was actually running cooler then it has been. When I followed the sound I found it to be coming from a small pool of water a top the rear portion of the lower intake. I'm not sure if this is leftover water from yesterday, or if my lower intake has a hairline crack in it, but I'm going to remove the upper intake and the fuel rail and check out what’s going on back there.
I noticed that the rubber boot for the closest fuel injector in this area was practically melted; I don’t think the water caused this, i remember cleaning one of those boots (might of been this one) which kind of weakened it, the water might of just made it worse. Again I’m not sure if this water was standing over from the incident yesterday or if this is a new issue. We'll see. At the moment, the engine is running fine, if not better then it has been.
Does anyone know if those 'boots' are supposed to hold back water or something? The water appears to be leaking from around, or underneith the boot. When i mean boot, there is a peice of rubber surrounding the base of the injector. Are the injectors watercooled? I can't figure how how im getting water on top of the intake, when all the water passages and junctions are below this plane. So far, driving short distances doesnt cause the leak to appear, its when i drive some 20 miles or more.
