Since the New year is appoaching I thought id start a thread on my build.
Ive put alot of thought into what I want to accomplish. Spending alot of time reading up and searching this site for info and ideas. Which has been very helpful.
Parts that I have as of now
91 explorer I picked up for $250 bad tranny.
Dana 44 and 9" from a 79 bronco
33/12.50-15 thornbirds with chrome wagon wheels
supercharged 3.8L motor from a 89 tbird
Reason for the motor swap is for the challenge of getting it in and running. The other reason is just to be different. Not everyday do u see a supercharger under the hood of an explorer. The torque is much higher that the stock 4.0 too.
For the 9" swap im not to worried about that conversion. I was looking for some thoughts on if I should place the axle in the stock location or move it back and if so how far?
As for the front I want to do the conversion with leafs not coils. This is the area im going to need some insight and help. Ill get into that when the time comes. But please post links to your rigs or someones you know of that has done the front leaf conversion.
In the mean time I am looking for ideas on a driveline. "trans/tc" I have the original b&w 1354 from the explorer and then I have a b&w 1356 from a 91 f150. I like to use one or the other to save on the cost of the build.
I believe the ford 4.0 and the 3.8 have the same bellhousing bolt pattern? So what transmissions do I have the option to go with?
Thanks for the help and I cant wait to get going on this project
Doug
Doug
