E-brake and Superlift 5.5" | Ford Explorer Forums
Mat R
Woodinville(and all of western)
'85
I installed the supplied extension that came with rear part of the Superlift 5.5" kit, but the only problem is that I also have a 2" body lift, which had cause my E-brake to already be tight. Now, I can get the cable all together, but is so tight I can't even get one click out of it. I thought I remembered some of you saying you had bought Ford Ranger E-brake cables to fix this? Has anyone else this problem?
Thanks,
E-brakeless Mat
ideas anyone?
hmmm
Did you ever have the e-brake recall performaed Mat?
If so, check it see if there is chock in the ratching mech. I found with my '93, with that chock in we couldn't get it to move either.
Pull out the chock, and bingo! everything adjusted.
Left rear Ranger e-brake.
A chock? hmmm... I'm not really sure, but I'll check. Even if that is there though I doubt that it is the problem because the problem is simply with the length of the line. I'll probably have to visit the junk yard or something.
Mat
