I thought I had the blend door actuator problem discussed many times on this forum, so I took the trouble to remove the old one and get a new one.... what a royal pain that back bolt is! :frustrate
Just to check all possibilities before reinstallation, I disassembled the old actuator and inserted its gear into the blend door hinge and used the old gear as a "doorknob" to move the blend door back and forth and it works fine. So I know my blend door is not the issue. Ok, so then it was time to check the actuator.
After all that trouble of removing the old actuator, I hooked up the new one before installing it. I played with my temp controls all the way from Max A/C to full 90 degree heat and the actuator never moved. I checked my owner's manual and found that fuse #10 seems to be the one controlling the actuator so I checked the fuse and it is fine. At this point I'm scratching my head :scratch:
It seems that I have another control issue of some sort. I did find another thread wherein someone mentioned the possibility that the entire dash A/C control panel may be the culprit (the one that has the readout of temperature).
I've already chased this with $40 in tools to get that d@m# back actuator bolt off and also the price of a new actuator I didn't need, so I'd like to make sure before going further. Has anyone else had this problem? Is there a way to diagnose the panel [with voltmeter/etc] to see if that is the problem? Is there another fuse and/or relay under the hood that might be fried? Could there be another thing that is causing the problem?
