Fiddlehead
- January 24, 2015
- Oklahoma
- 1994 Ford Explorer XLT
I am helping a friend troubleshoot and fix his 1994 Ford Explorer XLT w/ 4.0L, A/T, 2WD. He had the motor replaced about a year before having this problem. Then 6 months before the problem, he had the fuel pump replaced. He suddenly began having problems starting the engine and then it quit starting completely. He bought another car and set this one on the curb for a year before I got involved. The first time I looked at the Explorer, I opened up the hood and started checking fuses and found the 30A, EEC fuse blown. I pulled the 30A fuse from power locks slot and put it into the EEC slot. It started right up. After a couple of days of driving it intermittently, it quit while he was driving it. We pushed it a couple of blocks home, where it still sits. We have replaced the fuse several times where it quickly blows with the key off, most of the time, but sometimes we have to turn the key on. Weird! I pulled the EEC relay and tested it with a DVOM. It checks good, but I haven't manually applied power to it and checked it. I do feel it click when the key is turned on. After having read a lot on this and other forums, I decided to perform continuity test on the wiring from the EEC plug.
Today, I disconnected the battery and the unplugged the EEC. Below are the results both with the EEC relay, Fuel pump relay and the AC WOT cutoff relay (all 3) in and (all 3) out. I used the pin 60 as the ground (black lead on the DVOM) and checked for a short to ground at each pin with the red lead. I have listed only those pins that showed a short to ground.
With Relays In – 3, 6, 8, 9, 10, 12, 15, 16, 17, 20, 21, 30, 33, 35, 37, 39, 40, 51, 53, 57, 58, 59,
With Relays Out – 2, 6, 8, 9, 10, 16, 17, 20, 30,
After examining a wiring diagram that I found tonight on this site, I know that those listed below are grounds and can be eliminated from the list of possible shorts; 6, 16, 20, 40,
I don't understand why I picked up a short on 2 after pulling the relays.
I also tested for shorts to ground at the EEC data link under the hood. This was done without the relays in their sockets. I found that there was a 31 ohm reading on the pink/Lt. Grn wire which is shown to be pin 17 on the wiring diagram.
I am still scratching my head and trying to figure out what the data is telling me. I have checked for melted and worn wires in the engine compartment, but I cannot consider it thorough enough to eliminate the wiring. I have not been under the car yet.
I have had considerable experience with electronics and wiring since I was in my teens, but this one has got me. Any help with this would be greatly appreciated.
In His service,
Fiddlehead
In His service,
Fiddlehead
