shucker1
- May 4, 2008
- Metairie, Louisiana
- 98 XLT 5.0
I posted a while back with timing chain iuuses on a 98 Explorer 5.0L
What had actually happened is that I had a intake valve stuck closed #6 Cylinder. It bent the pushrod to a banana!
The heads are now off and in the shop getting a 3 angle valve job.
The bottom end of the block is good. Factory hone markings are still there after 105K miles. Lifter valley was clean with no sludge build up.
I am looking into installing a mild street cam. (E303 in mind). Ford Tech Line stated EEC-V will not work with this long duration camshaft. It will run rich.
Now I am researching tuning software. I am looking for possible recommendations and \ or sucess stories, failures.
