snobrder9186
- May 27, 2003
- Cleveland, OH
- '98 Sport 2Dr 4WD
I'm going to build my own box for my 2 10" subs which both require .75 cu. ft. What I was wondering was if I build a box to 1.5 cu. ft. if I should put in a divider between the subs or if I should just leave it open as one large cavity. Also, when I asked about how to wire 2 subs in parallel before someone suggested that I wire the left sub to the right sub's terminals then wire from one of the subs terminals wire to the enclosure's terminal cup, then to the amp. Would this work? Or would one of the subs be recieving more power than the other? Thanks A Ton!
