DylanAB
- June 23, 2022
- Windsor, Colorado
- 06 Ford Explorer Limited
Good Morning,
I have 2006 Explorer 4.6 (Limited), it has been in the family since it was brand new and well maintained. It has been driven very easily as only a commuter vehicle and has never had any mechanical issues. Lately though, the Engine Oil Temperature sensor code (P0197) has been going off. I have replaced the sensor and the wiring for this and still have the same issue. I looked in the service manuals and the only thing remaining to check is if the ECU is going bad according to the service manual. I know newer cars do not have this and am wondering if I just leave it alone as is, will it cause any issues or damage? It currently does not affect the way it drives at all. I can clear the code but it will still come back within the day. I saw that someone on here had a similar issue a little while back but all they did to fix was wrap the cable. Is there a more permanent fix? Or is it even a major issue to be concerned about?
