Exhaust Help | Ford Explorer Forums
Exhaust Help
Rage1973
Yuba City, California
98 Sport
Hey Everyone, I sure could use some help with the problem that I am having. I am looking to replace my MAC exhaust back with the stock one. I am stationed in Germany, and traveling around with the MAC doesn't work very well. Also I just can't run down to the local parts stores and pick one up. I love the exhaust, but it is just to dam loud for traveling for hours at a time.
I am having problems locating the correct exhaust system that came off it orginally . I have the dual in and single out muffler, but the pipes extends out about a foot and half in the front of the muffler. The ones that I have seen, are for a four door model, which wouldn't work fo me since I have a 2 door.
Any advice, inputs, or part numbers would be GREATLY APPERICIATED.
I have orderd parts through Advanced Auto before if that helps.
Later
Jeremy
So nobody has any idea what I am talking about?
Pipes can be cut or added to and usually are when changing mufflers. The actual size of the muffler itself is usually the determining factor as to fitment.
You don't necessarily need an OEM muffler. There are lots of quiet ones out there in the aftermarket.
just curious where in Germany you are?? K-town here
Wurzburg...
Are you in the military? I go up to Ramstein AFB often for supplies.
Rage1973 said:
Wurzburg...
yup air force and work on Ramstein, and based on where you are i assume you are army? They still planning to close wurzburg? It sucks, they have closed all of the good bases in Germany, not that ramstein is bad, but rhein main and frankfurt were much better! Frankfurt was a never-ending party when I was there back in the late 90's (and when the exchange rate was much better!)
