Autimous
- December 25, 2004
- San Jose, CA
- '97 Eddie Bauer
This related to a 91 4x4 Eddie Bauer with about 211k. The tranny was alegedly rebuilt last year.
So here's the thing....
I changed the oil/filter, and also the transmission fluid. As I'd previously changed the tranny fluid and filter a few hundred miles ago, I decided to just change the tranny fluid this time to see if I can help get thank gunky crap out that like to sit in the oil pan.
No it could be totally unrelated, but I don't see how, but when I just took it out for a short test run (about 10 miles) it was shuddering in the highway like it didn't know which gear to go into. This isn't the first time this has happened, when I first bought it about a month ago it did the same thing. But that went away after a day or two so i figured that perhaps the previous owner wasn't up to scratch with his maintainence. Anyway, it went away.....
Then it started sticking in first gear on a cold start up, so after surfing this site thought it best to change the tranny fluid/filter, and after a week or so that problem went away. So I thought I change the tranny fluid again, just to make sure. Then I noticed this shudder thing again. I'm a bit worried because i was surfing this site to find what it could be and someone put a scary post about the same problem causing a rebuild.!?!?
Anyway any advice or reassurance would be very welcomed.
Whilst it may be completely unrelated i also changed 1 spark plug (I changed the other 5 a month ago). So I'm also concerned that it might be the piston underneath it. Oh bollox, I really don't know. I'm an aspiring DIY mechaninc who is learning all the time so please give me your advice.............
