Expy to Nav ECC interchangable??? | Ford Explorer Forums - Serious Explorations
shaggymane
topeka, kansas
91 navajo
A local out of the way bone yard where parts are cheap just got a 91 4dr Exp AT, AC 4x4. I have a 91 Navajo.
I thought it would be a good idea to grab some spare parts. One of them being the computer, the ECC.
Would they interchange? The Expy tranny is mechanical/hydraulic so seems to me that shouldn't be a problem.
However, O R's lists 11 different part numbers for both the Nav and the Expy and then also add things like "With ID Number F17F-12A650-ZA"
Is That a reference to the vin number?
eta neither vehicle is a Cal vehicle
bumping this thread because i still think someone knows
Usually when you replace the PCM, you try to match those numbers so the calibrations all match up.
As far as I know (ignoring transmission differences), engine management is basically the same on all '91 4.0's. The only difference is internal calibrations inside the PCM's programming. Except for differences between auto/manual transmission, the PCM's should interchange ok.
I have a 93 and the computer code for Oreillys is F37F-ZB
Found a 94 Ex sport same everything and its a F47F-NB
I "Ass"ume that the first number is the year of the vehicle... Since you stated the F17F is from a 91 that assumption holds water... I am still trying to figure out what the first letter in the ZB or NB means...
I am putting the 94 NB in place of my 93 ZB tonight... Will let you know
So it's basically a go. Curious what variations on the internal calibrations might be. Would a heavier vehicle (4dr) with a tow package have a longer pulse width on the injectors for more power? anything like that?
93F-Explorer, How'd ya make out?
Just to inform you the 94 did not work in my 93...
93 is batch fire and 94 is sequential fire... so I didnt have any luck =(
That's the tough part about swapping PCM's to a '93. Some '93's are batch fire and some are SEFI.
