f150 spacers and coil spacers | Page 2 | Ford Explorer Forums
they are like $20 each at Ford. The part numbers are listed in this website.
You are looking for a 2wd F-150, 89-91 I believe.....
If you find them at the junk yard keep in mind you will have to droop the front beams to get the coil out of the bucket, this requires jacking up the frame, so a jack and stands are needed....or help from the yard..
ok guys heres what i want to do, tell me if it will work or not, i found out i have 3"drop brackets, if i wanted to get 6" coils what will i need?
will i need these 90-97 Ranger Adjustable Alignment bushings 0 - 2 degree ???
Part Numbers?
I think the part numbers for the Ford factory coil spacers are:
F2TZ-5A307-A
F2TZ-5A307-B
My question is will these work or fit on a 2nd Gen 1999 Sport?
no see other post :)
410Fortune said:
on a 4x4 truck with the dana 35 TTB axle, yes it bolts right on, no mods needed, except alignment and cams
so i would need an alignment "$40" and camber bushings?
What do that cost? :D
Alingment with installation of cams is usually about $100.
they will supply the correct cams
