cdubbs7859
- May 12, 2019
- Lakeland, FL
- 2015 Ford Explorer XLT
1. Wire the inverter so it cuts off when the vehicle does. This is the route I went. Assuming you followed my directions to this point, the rest is easy. With your passenger side door jam trim, glove box door, and carpet pulled back, you will have easy access to bare metal to make your ground connection. The black wire with yellow strip on your harness is your ground. Find a suitable location to place a self tapping screw and attach your ground. Next, using 10 gauge wire, extend the red wire from your inverter harness. You’ll be routing this to the battery for this install so don’t cut anything for now and leave it hanging.
Next you will need to extend your ACC wire. This wire will go to the fuse box and acts as the “remote” wire that actually turns on the inverter. If you have ever installed a car stereo or amp, you’ll be familiar with this concept. The wire is 18 gauge wire and will be much smaller than your power wire. Extend this wire and for a factory look, I like to roll both wires together in electrical tape. When you’ve done so, begin routing your new “harness” up and across where the glovebox is(there are existing wires there, secure them together with zip ties for a clean, factory look.
You’ll need to route this harness over to the driver side. This can be done by fishing them through the front most part of the center console. This is self explanatory and requires no panel removal. Once you’ve gotten your new harness over to the driver side, remove the plastic panel under the dash. This is done by removing two screws and carefully removing the panel. This will allow you to access the fuse panel as well as allowing you to properly route/secure your harness. Route your harness logically, following the path of current harnesses and avoiding moving parts. You should have a length of 10 gauge wire that will eventually go to the battery and your 18 gauge wire should be routed and secured near the fuse box.
