biggiesize
- December 17, 2008
- Martinsville,Va
- 1999 sport
While I sit here running things through my mind,Im thinking about all the solenoids in the 5R55E.What im wondering is this:If the EPC,TCC or the other 4 shift solenoids,all of which allow fluid through them goes bad,could it restrict the amount of fluid that is going into each shift solenoid to shift gears?Is there an override to allow fluid to bypass these solenoids to prevent failure of the particular gear that the solenoid controls?If one of these solenoids goes bad will I get a light on the instrument cluster or is the trans not hooked up with warning lights?Maybe Im just misinterpreting hoe these solenoids work.
