patrickemb
- January 20, 2007
- oklahoma
- 99 limited
I have read dozens of post and can find nothing similiar to my problem. I have a 99 limited explorer V-6. I have made one post and got no answer. Thought I would try again. Have learned a little more about my problem. Every time I make a turn either direction it feels like the front wheels and drive are wanting to lock up or in full time 4X4. I have checked out the CV joints and they appear fine no boots are cracked or broken. Can you have a bad joint if the outward appearence is fine? Droped the front drive shaft and the problem goes away. Pulled the T-Case motor checked it, seems to operate as it should. Thought about the brake line going from the steel to caliper replaced drivers side but didn't fix problem, other side looks ok as well. hubs seem ok also. Any one have any ideas, this is really driving me a little nuts, don't mind fixing it if I just knew what to fix.
