Dignan
- July 31, 1999
- Idaho Falls, Idaho
- '99 5.0
Well, this is what happened. I live in Texas, my Explorer and motorcycle were in Utah, so I decided to tow them to Texas when I visited Utah. I changed the fluids and charged the battery since it had been sitting for a while. It fired right up once the battery had some juice. I left it running and loaded the motorcycle on the trailer first. Then went back to drive the explorer up to the trailer. Walked over to it and it was dead. Cranks great but no fuel. Can't hear the whine of the pump when turning the key. I have been searching for 3 days and can't find exactly what I need. I have checked the inertia switch and it is in the proper position. I next went to the Power distribution block to check fuse and relay. Fuse is good. Relay is difficult to get to so tomorrow I will probably unbolt the power distribution block to get to the relays underneath, but what I found was the VIP connector dangling and another single wire in the same tape bundle that was also dangling and also stripped. Should these be plugged in somewhere under normal circumstances? If that doesn't make much sense, maybe someone could post a picture of a normal relay setup for a 91.
