5.0L96Exp
- October 23, 2005
- Ottawa, ON
- 96 XLT
I still think we are on different pages here. There is no proportioning valve per say. The "proportioning" is built directly into the HCU and MC. That is, the MC determines Front to Rear brake pressure (via different pri/sec spring rates), the HCU determines (while ABS is activated) the pressure applied to the FL, FR, and rear brakes. ie the HCU can raise/lower pressure to the FL, FR and rear brakes as needed to prevent skidding. There is no way "proportioning" could be after the HCU since the HCU has 3 outputs, 1 for the FL, 1 for the FR, and on for the Rear brakes. It simply doesn’t make sense. Also, there are only 2 lines into the HCU, one from the MC primary and one from the MC secondary.
However, the original question remains. Which valves open/close when the VALVE button is pressed? And where does the air in the HCU end up after the 60 seconds. It seems to me, from the HCU fluid routing diagram that when the pump is running, the DUMP and ISO valves are opened, the accumulators will fill with brake fluid under pressure forcing any air around in a loop. Unless of course the HCU is designed with some sort of loop de loop routing that causes the air to get stuck in the primary leg. Once all the air is trapped in the primary leg, (the DUMP valves are now closed restricting fluid from entering back into the accumulators), the brakes are bled normally starting with the RR, RL, FR, FL.
If anyone has the name and number of a Ford dealer that is willing to let you talk to a tech and ask all sorts of questions it would be greatly appreciated. I have yet to find a dealer that is willing to answer any technical question, or any question that would in any way make them liable. ie The moment you so much as mention brakes, abs, airbag, cup holder, floor mats they tend to freak out and tell you to they will have to look at it and replace the parts as needed.
