- August 1, 2008
- MO MO
- 94 & 95 XLT's
I removed the lower plastic dash panel and the steel panel behind it and used a 2' extension to remove the 4 nuts from the brake booster studs and then had to lay on my back to get to the remaining 2 bolts that go up into the dash support/fire wall.
With the 4 booster nuts off and the booster rod disconnected from the pedal assembly, you should have enough play in your brake lines to pull the booster forwards off of the firewall enough to give you the room you need.
Yeah, I did the same thing. those top ones were fun! ....NOT!
I removed the drivers seat and laid on my back to work under the dash.
I will do the booster deal so I can get the bracket out. I was afraid I had to do something along those lines. Oh well, thats the way it goes..lol
